Show off your aftermarket gauges!
#22
RE: Show off your aftermarket gauges!
ORIGINAL: Mark99GT
+1 Gauges look AWESOME The cluster is from speedhut.com What type are the rest of the gauges?
Oh, and any pics in the daytime?
ORIGINAL: GTnAZ
Tac2clu.... where did you get your gaues?
They are bad ***!!!
They are bad ***!!!
rest of the gauges are from speedhut as well
2xa/f
1xoil
1xwater
1xfuel
i got pics of daytime somewhere will have to look
#23
not to hijack but TAC2CUL did you ever do a write up of where to wire those gauges when you did they gauge install writeup let me know thanks....or is it easier than it looks? any tips I would appreciate Im going to be doing water,oil,vac and wondering best spot to line up my power to headlight ****?
#25
Here ya be. I luv the lunar series gauges.
[IMG]local://upfiles/5875/F94204D59E274A7AB945E17369402BB3.jpg[/IMG]
[IMG]local://upfiles/5875/8AAE2343D9604AF5A6CBC7D1C5F7EB1A.jpg[/IMG]
[IMG]local://upfiles/5875/E6178445E56A471090C6A6A83AC38F3A.jpg[/IMG]
#28
Is that the AEM wideband A/F gauge machwon? I just ordered that and an autometer sport-comp boost/vac gauge w/ dual pillar gauge pod. Well actually...got my parents to order it as my christmas present! lol
#29
ORIGINAL: ZW99GT
How hard would it be to get Nitrous bottle pressure gauge up there on the pillar? Im looking to get a 3 gauge cluster with A/F, Bottle pressure, and fuel pressure.
i just checked out speedhut and i love they way you can customize them, anyone have a closeup shot?
#30
ORIGINAL: sitnlopro99gt
its pretty damn easy to wire **** up....all i used was a test light
the A/F you will have to figure out how u wanna run the wire(to PCM or out to the sensors themselves) i ran mine to the pcm and was super easy to do
headlight **** all i did was use a connector on the blue/white wire(i believe dats the color)
and ran a single wire down below my steering wheel and connected all my dimmers to that 1 wire......so far so good
i used different sources to actually power the gauges themselves.....i used the trac control button as the other buttons wouldnt work when key was in the run postion for whatever reason i believe and a fuse box connection that way i wasnt drainin to much off 1 line....
i never did the actuall elctrical connection addon to my writeup.....i should of done it all at once and did the writeup but since i HATE anythign elctrical i tackled dat first
you have anymore question shot me a pm and im sure i can help ya
