Just installed a/f gauge..questions
The LED lights are staying on lean, even when I open her up, it never even reaches Stoich. I hooked it up to the Gray wire on the drivers side, is this the correct wire or did I do something wrong? Thanks!
RE: Just installed a/f gauge..questions
Come on guys, I need a quick answer so I can make sure its right and correct it if not.
so the needle never moves?
then yeah u have it hooked up to the wrong wire.... i dont know which u should use as i hooked mine into the PCM directly ok found this on google its the Red wire with the BlK strip on the o2 sensor doesnt say what side though..perhaps either? |
screw it, i'm hookin it up via PCM
Wow, I wish I had hooked it up that way to begin with. MUCH easier. I know its useless but it's a pretty cool light show.
glad u got it sorted out :D
