Turbo anyone?
RE: Turbo anyone?
yea twins are hott - but from my research a properly sized single is just as good - and half as likely to fail - for some reason I hear all of these horror stories about the complexity of timing and tuning twin systems... and the guys im dealing with are not even close to 7k for just parts
RE: Turbo anyone?
also a centri is a turbo... just powered by a pulley, and as long as the intake temps are kept in check I dont see why there should be a problem, turbos are by far more tried and true then s/c's... but I am no expert, hence my post
Kbs are the next best thing - but pricey
RE: Turbo anyone?
We're as STS dealer as well. On a stock motor, most people don't like to exceed 6 lbs for reliability but that doesn't mean people follow that advice! To control detonation, we suggest you use alcohol or water injection. That will let you run a few more lbs of boost and not have to worry as much about detonation. It also cools the intake charge
The idea behind the remote mount it to make installation easier and to keep the engine heat down in the engine bay. Excessive heat can damage components and shorten their life.
RE: Turbo anyone?
ORIGINAL: ben790450
Dude why dont you just man up and get a quad-turbo set up like on a bugatti? C'mon!!
i have dyno sheets to prove this
RE: Turbo anyone?
ORIGINAL: mvr
we all know you need dual superchargers to spool your 4 turbos better. also if you have 3 turbonators right after your intake its good for another 24psi.
ORIGINAL: ben790450
