My used S/C kit installed(by me)! Pics / dyno graph.
RE: My used S/C kit installed(by me)! Pics / dyno graph.
When driving the car I only take it to 6k, don't want to push the rotating assembly too hard. 2000gt4.6 is right though, the blue lines are my NA lines and there wasnt much point taking it past 5800 on that and he started it down lower (not sure why on that, the blue lines were done like a year ago).
I had to slightly increase the diameter of one of the holes on the main bracket so I could fit a fatter bolt through it, one that would screw into my stock mounting spot on the engine. Ummm I think I used a stock bolt in one area where it said to use a supplied one (because I couldnt find the "supplied" one, even tho I thought I had checked for all missing parts). The inlet tube coming off the S/C amost rubs one of the radiator mount spots, I used a flex radiator hose instead of modifying my stock one. Mostly small, little things...nothing very complicated at all.
ORIGINAL: mikev08826
Those are some shaky graphs...
Yup, I read it wrong. Damn you are my hero.
99.99 percent sure this is normal. I looked at the graph mine made before they did the smoothing and it was alot differen't than afterwards.
ORIGINAL: 2000GT4.6
At least you have someone to look up to.
