What's with my RPM's and ideling
12-14-2006, 02:32 PM
After starting my car (at any temp.) and coming to a stop in neutral (5-speed), my RPM’s slowly work it’s way down to an idle. Then the idle pauses at about 1,000-1,300 RPM’s for about 2-3 seconds and drops fast to about 300 RPM’s and bounces up to a normal RPM range. It just about stalls. What do yall about that?! Thanks for your replies.
[IMG][/IMG]
[IMG]local://upfiles/52911/A1F2A7F630AC4F1286DAEF39BE777836.jpg[/IMG]
12-14-2006, 02:35 PM
RE: What's with my RPM's and ideling
I kinda have the same problem as you. Mine at idle bounces between 500-800 really quickly over and over.
12-14-2006, 02:37 PM
I know what you mean. I don't know if it needs a tune up or a timing problem. I have no idea.
12-14-2006, 02:53 PM
fuel delivery?
12-14-2006, 02:56 PM
IAC
12-14-2006, 02:58 PM
most likely IAC could be a clogged fuel filter though...
12-14-2006, 03:59 PM
i'm guessing it's a gummed up IAC also
12-14-2006, 04:25 PM
very small air leak
12-15-2006, 09:01 AM
Thanks for the replies. I'll look into it. And hopefully it's not oo much of a problem.
[IMG]local://upfiles/52911/18D45B065EA1440AAC6F2A36FCA0C077.jpg[/IMG]
12-15-2006, 02:36 PM
i agree with the iac. the idle is supposed to drop slow to around 1k, but it's not supposed to go below the factory idle rpm.
CS2007
06-25-2019 09:45 PM
Stone629
The Racers Bench
66
06-02-2016 09:52 PM
Sixer4Life
10-12-2015 04:26 AM
Omgitsa88Stang
10-05-2015 07:33 AM
lmurf60
09-24-2015 10:07 PM
