shocks and struts
RE: shocks and struts
yeah they are both easy to do struts you only undo the top not in the inside sturt bases and then undo the 3 bolts in the spindle base 1 not holding abs on and the other 2 holding actual strut on almost same steps as installin springs and then the back you just lift up the rear put jacks right by the torque boxes let the rear hang , put tension in the rear and undo the shocks inside nuts and then undo the single bolt on each side for the shock and repeat the steps
