Modded 96 Gt on Ebay
Buy it now for $7000, is it worth it? Also what kind of rwhp should it be making?
http://cgi.ebay.com/ebaymotors/Modde...QQcmdZViewItem
1/4 mile time of 12.97
Mod list:
Suspension:
Full UPR tubular coil over front
QA1 front springs
GMS upper and lower rear control arms
Poly bushings everywhere
Poly motor mounts
Cobra rear sway bar
MaxSpeed progressive rear springs
KYB AGX adjustable shocks/struts
17x9 Cobra R's with 275-40 Yokohama AVS-1000's
Engine:
Densecharger CAI
Pro-M 80mm MAF
Accufab 75mm TB
Trickflow Plenum
1/2 in plenum spacer
PI intake
PI heads (10.5:1 CR)
VT Stage II NA cams
MAC longtubes
MAC O/R H
Flowmaster American Thunder catback
Drivetrain:
Fidenza Al Flywheel
Spec Stage II clutch
Upgraded T-45 (kevlar blocking rings and upgraded shift forks)
Steeda Tri-ax
FRPP Al Driveshaft
3.73 gears.
Brakes:
Brembo Cross-drilled and slotted rotors
Kevlar pads
Stainless front lines
Linelock w/ custom Stainless lines
Mod list:
Suspension:
QA1 front springs
Poly motor mounts
Cobra rear sway bar
Engine:
Densecharger CAI
Pro-M 80mm MAF
Accufab 75mm TB
Trickflow Plenum
PI intake
VT Stage II NA cams
MAC longtubes
MAC O/R H
Drivetrain:
Fidenza Al Flywheel
Steeda Tri-ax
FRPP Al Driveshaft
3.73 gears.
Brakes:
Kevlar pads
RE: Modded 96 Gt on Ebay
ORIGINAL: JonBeast
140k and its obvious its been beat the hell out of....I'm gonna say NO BUY
Looks clean on the photos? Depending on how many miles are on the PI swap I think its a fairly good deal, definatly ready for some nitrous.
Plus the suspension mods.. lots of them there that would cost ya $$
Thats why i was considering the mods on it would cost me a lot more than that
ORIGINAL: 2000GT4.6
I dunno, just because its been to the dragstrip doesn't mean its been mistreated.
For a little more you could buy my buddies 00 that has gone 12.5
http://www.svtsnake.com/forum/showthread.php?t=21746
where you located? And how much more $?
ORIGINAL: Miliock
I know i am going to go get it, i dont like even giving deposits sight unseen
ORIGINAL: bransdaman78
dont buy sight unseen - much more importantly driven... this 100000k more true if the car is not under warranty!
