plastic intake manifold!
my intake blew apart tonight as i was walking away from an 03 cobra. i will be going with a paxton novi 2000 soon, and i am not goin to replace with stock intake so i need to kno which intake to replace it with? bullit , p51, typhoon? it will eventually have heads cams and built shortblock with alot of boost so i need the best intake for this setup? thanks
RE: plastic intake manifold!
Not sure which to get, but I believe they are all good brands and would be a good choice.
I guess that Nitrous really helps when it comes to running with an 03/04 Cobra,
Yikes. Just curious, what kind of symptoms did you have when your intake blew? I'm just waiting for mine to blow...
Supposedly it's not a crazy easy fix, I guess you gotta get pretty deep under the hood.
nah i have only had my car since november of 05! is there a recall on the 2000 intakes? yes i was spraying nitrous and it was just a very very loud backfire, at first i thought i blew it up...but its not knocking or anything, holds good oil pressure, car will run but wont idle well....acts just like a big vaccum leak and i looked at the intake and theres a big hole in it where it blew apart!
but it was nice pulling away from the 03 cobra, the guy thought it was bad *** car but i was walking him down pretty good
ORIGINAL: mikev08826
You never got a letter from ford saying that if you blew the intake manifold on your 2000 they would replace it for free?
He is talking about spraying the engine and blowing a hole clean thru it with a nitrous backfire.
