Which centrifugal s/c do you run?
Old 12-18-2006, 01:27 AM
handyandy
handyandy's Avatar
Default Which centrifugal s/c do you run?
What kind of centrifugal superchargers do you guys run?
Between some known brands, like ATI procharger and Paxton Novi and others which one would make the most power with the same boost on the same car?
Do you buy from ebay? or do you order straight from the site and have a shop install it?
handyandy is offline
Old 12-18-2006, 01:29 AM
SOHCtimes2
SOHCtimes2's Avatar
Default RE: Which centrifugal s/c do you run?
They all make the same power with the same boost actually...However I believe that a paxton or vortech w/ an intercooler will make more power than an intercooled procharger. Since non-intercooled vortechs / paxtons usually make the same power as intercooled prochargers.
SOHCtimes2 is offline
Old 12-18-2006, 01:55 AM
Car_Ramrod
Car_Ramrod's Avatar
yep...and all are pretty good brands...just stay away from powerdyne.
Car_Ramrod is offline
Old 12-18-2006, 01:58 AM
Davojan59
Davojan59's Avatar
hmm...i beg to differ...the non-cooled vortech/paxton doesnt make nearly as much power as the intercooled procharger...i got one at 8 psi with only and o/r x and lm1 catback and the numbers u see in my sig were before the lm1...they were with flowmasters welded in so there u go
Davojan59 is offline
Old 12-18-2006, 01:59 AM
96_LAstang
96_LAstang's Avatar
Im a Kenne Bell fan myself
http://www.kennebell.net/index.htm
96_LAstang is offline
Old 12-18-2006, 02:07 AM
V8Cody
V8Cody's Avatar
He said centrifugal... not Twin Screw
V8Cody is offline
Old 12-18-2006, 02:08 AM
bransdaman78
I ♥ Acer
bransdaman78's Avatar
yea incorrecto - prochargers make a significant amout more than vortech or paxton at same boost levels - procharger has a higher step up ratio and a better impeller
bransdaman78 is offline
Old 12-18-2006, 02:19 AM
96_LAstang
96_LAstang's Avatar
my bad, i was just giving another idea
ORIGINAL: V8Cody
Old 12-18-2006, 02:25 AM
Davojan59
Davojan59's Avatar
exactly...even if it is a cooled vortech its just about the same power at the SAME boost level as the procharger....but it costs more...and like i said before i like all three brands of these centris but it is what it is
Old 12-18-2006, 02:31 AM
2004YellowStang
2004YellowStang's Avatar
ORIGINAL: bransdaman78
Funny you say that.... check out superchargersonline.com and they do a independent side by side comparison of the procharger and vortech. For the lazy, http://www.superchargersonline.com/i...1sc_report.pdf If you read it not only does the vortech have a 73% efficency rating compared to the 52% efficency rating of the procharger but the procharger is the least efficent supercharger they've ever tested. Don't believe everything you read in their ads.
IMHO stick with vortech or powerdyne. Intercooled or aftercooled setups always make more power than non-cooled. Colder air = denser air = more power. Plus you can run more boost which makes even more power potential.
2004YellowStang is offline
Quick Reply: Which centrifugal s/c do you run?
