i need spring info
i need spring info
anyone know where I can get stiffer springs that do not lower my 01 GT coupe. My daily driver can't aford to be lower to the ground but I figure that if I get new shocks and stiffer springs it willl handle better.
RE: i need spring info
For cornering, you want to stiffen the sway bars more. They won't affect your ride quality, but will control the higher amount of roll you have with the taller car.
You can get 1" lowering springs with a higher rate and add coil springs spacers to add the height back in.
I have the nice wide tires and rims(look at sig). If I just say screw it and lower the stang a little....what are the best handling and ride quality springs, shocks and struts out there and where can I get them.........Thanks for all the info.
mungodrums
09-28-2015 10:54 PM
mungodrums
Suspension
09-24-2015 10:12 PM
