Rear Axle Noise...HELP!! (With pics)
I posted this not too long ago, but didnt seem to get that much of a response. It was kinda of hard describing the noise, even without pics. So I took some pics so you guys can get a visual idea of whats happening and hopefully help. Heres the problem:
There is a Horrible "squeaking", like a crank squeak noise that is coming from the left rear side only. I can hear it when im cruisng at between 10-35 mph, but it gets really loud whenever I make a left turn or a U-turn, whether its in a parking lot or on the street. Its basically sounds like squeaking metal on metal that needs to be oiled or tightened up. So, today I took my tire off and had a look at whats going on. Every bolt was tight, and nothing seemed to be rubbing anywhere. These are pics I took and hopefully you guys can point me in the right direction. I dont want to take it to a shop and have them pull some schiet out of there a$$. I look forwrad to the replies.
RE: Rear Axle Noise...HELP!! (With pics)
blown quad shock. i had this hapen to my race car. you can either replace it or takeboth off and get rid o them completely. but i had a blown quad shock and whenever i wold make atur it would cause a horribl ginding noise.
Believe it or not, it could just be your e-brake line rubbing against the chassis. You said left side so I'm thinking that. While your car is parked push down on the rear left side to see if it makes that noise. If so, reach under the car in front of the left side rear wheel, there is a bracket holding the e-brake cable and give it a push downward. Hope that helps!!!
Might be all wet here but shoudnt there be no gap in the red circle in pic.
Isnt there suppose to be a thick rubber gromet there it looks like you could shake your shock back in forth.
[IMG]local://upfiles/46815/04A22189FC70451997912543F497C6DA.jpg[/IMG]
is thatone of therivets from the inner pad ?? that brake piston is extendedout a lot .looks like the inner pad is gone .
[IMG]local://upfiles/45178/35CE90561D374B0DADBD496A92B131F6.jpg[/IMG]
ORIGINAL: David_K
blstoff-would a worn brake pad make that much noise when I cruise around? If that were the problem and I were to replace the pad, should I replace both right and left side along with the rotors as well?
ORIGINAL: PntyDrpr
You seem pretty positive that its a blown quad shock. Im still kinda of a noob when it comes to the intericate stuff, but where is the quad shock, and how much do they run to replace it? Could I do it myself, or do I have to take it somewhere?
[IMG]local://upfiles/20167/20A733FB219E4C48A9942C237E1CF5C0.jpg[/IMG]
