WINTER MOD: 10" CONVETER/BIG RESULTS-DR's ALSO
Well after doing the basic mods and not getting great results I have deceided to get a 10" converter and a set of DR's. Really need help with the DR's also as I read different things. What I have gathered is the M/T's are the best for the track but they are NOT streetable. BFG's are very good, streetable but will only last 5000 miles, maybe less and not good in rain and finally that NITTO's are the most road worthy DR's lasting as much as 12K miles but need to be heated to get them to stick well. Sorry I got off track but the DR's are an important part of this mod. I can expect possibly as much as a drop in et's of .75, maybe more!
TCI did a test of their not too good 10" and got a .4 quicker time, on the dyno went from a before of 254.6 WHP/284.1 WTQ and after 267.0 WHP/312.9 WTQ! These increases were attributed to the TCI 10" weighing 24#'s less than the stock 11" converter. At 3500 rpm's it made 266.5lbs/ft and with the 10" it made 312.9, an additional 46.4lbs/ft. Even at 4200 rpm's they saw over 20lbs/ft of additional lbs/ft of torque.
I am getting a much better converter than the TCI as it will withstand the torque being produced in 2nd gear and being LOCKED right after the 1-2 shift!
It will weigh 21lbs. less than the stock 11" and stall will be in the 3600-3800rpm range. These should be my best mods yet! mark
RE: WINTER MOD: 10" CONVETER/BIG RESULTS-DR's ALSO
Might I suggest somethingcheaper?
http://www.edgeracingconverters.com/
Edge Racing is awesome, there's a few fox body guys running these stalls (including myself) and no complaints what so ever, just pure performance. Call there and talk to Andre, the guy is a genious when it comes to building a custom stall.
ORIGINAL: sstangSo which brand are you getting...?
2800 rpm stall is not factory in theAOD. I can hardly imagine it being factory in the stock 4670w either, but I haven't really researched that tranny, that's agood amount of stall for a car to come out of the factory with. My car rolls with the brake released also. What don't you like about the internals of the Edge Converters?
ORIGINAL: 92hatchLX2800 rpm stall is not factory in the AOD. I can hardly imagine it being factory in the stock 4670w either, but I haven't really researched that tranny, that's a good amount of stall for a car to come out of the factory with. My car rolls with the brake released also. What don't you like about the internals of the Edge Converters?
'98-up Mustang GT...2324...2737
'98-up Crown Vic....2024...2440
'99-up Police or handling package Crown Vic...2319...2750
'99-up 4.6L F150...2145...2505
'03 Marauder...2555...3011
The Marauder converter is the same as the '98 and up GT except that it has brazed fins and the GT does not. Mark
PS: THIS info is from Ford with the input torque in the 295lbs/ft. range. Also I am NOT an expert by far on converters but am using guys who specialize in the Ford 302's and 4.6 motors and AOD/4R70W trannies. As for the EDGE converters I can only show you a pic of the inside of a used converter. I am glad you like yours. Try getting your tuner to have it lock the converter right after the 1-2 shift at WOT. This lowers et but is harder on the converter.
[QUOTE=dirtyd0g]Here is a look at Edge racing's converter using the stock 245mm clutch. Whatever makes a sellable product I guess.
http://i6.ebayimg.com/02/i/02/cf/c9/16_12_s.JPG
Hope this link works! mark
They've got a few different levels of converters, which one is that the inside of? Mild Street Edge? Street Edge? The AOD is electronically controlled which=no tuner. My converter locks when I shift into 3rd gear.
ORIGINAL: 92hatchLXThey've got a few different levels of converters, which one is that the inside of? Mild Street Edge? Street Edge? The AOD is electronically controlled which=no tuner. My converter locks when I shift into 3rd gear.
Thunderbird & cougar Club of America.
Since most t-birds are auto's these guys need to have strong trannies and converters. I do not know what model EDGE that is but if yours is working fine for you I am glad.
I am getting a 10" with stall of 3800 rpm's from Alan aka dirtydOg at TCCOA. He supplies converters to Darrin aka BC-Automotive. Darrin makes some of the finest/toughest trannies for Fords with 4R70W's and possibly the AOD. Alan supplies the converters to BC. Check out the site and register. Go to the drivetrain forum and check out a thread about "the inside of a Marauder converter". You will learn a lot about converters and what is good and bad. Many pics make Alan's descriptions simple to understand. In the Jan. issue of MM&FF these guys helped change a 600WHP Stang change from a stick to an automatic because the owner was not enjoying the stick on the street with this low 11 sec. car! I believe since the article the car has gone into the 10's.
The key to Alan's converters is that the 10" and 9.5" have the capability to withstand being locked right after the 1-2 shift at WOT! That drops the et even more plus the stall! The 10" is also 21lbs. lighter than the stock 11.25" from what I have gathered. Stock is 56lbs. according to the mag article and Alan said his 10" weighed 35lbs.
Start with registering at www.tccoa.com and check out the drivetrain forum and that thread on the Marauder converter.
Thanks guys, Mark
