300rwhp
#22
RE: 300rwhp
ORIGINAL: MBentz
Are you reading the posts? If you go out and buy a Vortech V-2 SQ trim, ProCharger P-1SC or Novi1000, you will be at 350 rwhp with no other supporting mods.
ORIGINAL: incognito207
what about supercharging? what kind of mods would i have to do to make that kinda power?
You guys just don't seem to understand how TERRIBLE the NPI stuff is. The NPI 2v stuff is some of the most restricive equipment to ever be installed on a mustang. You can barely make 190 WHP stock and it peaks at like 4500 RPM.
If your going to do anything with a NPI car either do a PI swap, or if you plan on getting a blower, just swap the engine out with an entire PI setup from a junkyard. There is simply SO much more potential from PI heads/cams/intake than the NPI stuff.
#24
RE: 300rwhp
yeah, um.........stuff you can bolt on the car!
Headers, midpipe, catback, CAI/RAI, TB/plenum, intake, cams, tuner, pulleys!
And yes, I consider cams a bolt on because you can (for my car at least) use the Anderson cam tool to do it on Romeo blocks which have removable cam sprockets (02-04) and you don't have to pull the timing cover.
ORIGINAL: silverstang1996
what's all considered a bolt-on? i know of the throttle body, plenum, CAI, but what else is there for bolt ons?
