Engine Oil and Transmission Fluid
RE: Engine Oil and Transmission Fluid
ORIGINAL: Shelbyville
OK...Why?? Been using Fram for along time. Maybe I am doing something wrong. Just need to know whats so bad about them...
Stuck to the block. Did you tighten too much? Use a filter wrench or hand tighten? If you tighten too much you can damage the gasket. Also, did you coat the gasket with oil before applying the filter? I am not a big promoter of Fram. The selections at the local Pep Boys or Walmart are not that great. I am just saying I have been using Fram for about 10 years at least and never had a problem. Just curious as to whats wrong with them. You might have had an isolated incident. That never happened to me. I'd be more concerned about the filtration quality than anything else.
The telltale signs for a Fram Extra Guard are: It has 8 small holes for the oil inlet and a thin, cheap looking backplate, and is currently stamped with a "2Y". There are 5 very small crimps holding the gasket in place. If you look into the center hole all the way to the top of the filter, you will see a kind of "button" in the end cap of the cartridge (which looks like it's made of metal from there). This is the plastic bypass valve
Thanks. I wasn't aware of this site:
http://minimopar.knizefamily.net/oil...html#fram-ph8a
Guess I need to change my brand.
Check your owners manual. I have a 2002 GT and mine takes 6 quarts with a filter change. Cost depends on what kind ofoil you get. I prefer a synthetic but since I change mine every 2500-3K, I don't prefer to pay $6.00 a quart for Mobil 1. I get Pennzoil synthetic which is $4.00 a quart, but thats me.
ShaneB26154
35
03-04-2021 04:05 AM
inyadreems
08-21-2015 09:10 AM
Greyshot
08-15-2015 03:32 AM
1996, 2011, 416, caterpiller, engine, fluid, ford, location, mustang, oil, rp, synchromax, tranmission, transmission, wrong
