OMG!! MY ENGINE JUST SHUT OFF!!!!!!!!!!
RE: OMG!! MY ENGINE JUST SHUT OFF!!!!!!!!!!
ORIGINAL: rbstang
why are you going to buy a new IAC? you were moving at the time the engine shut off.. the iac is not at fault....
ORIGINAL: Aixtreme89
It doesnt matter if he was moving or not, he put is foot on the clutch and off the gas so the engine was idling. I wouldnt go out and buy a IAC just clean it with carb cleaner, and also clean your MAF I have been told (with brake cleaner since its mostly alcohol but dont qoute me on that, a ford tech told me that when he cleaned mine way back when).... Good luck
ORIGINAL: rbstang
CEL comes on when the car dies.. Turn your car to accessory mode the check engine light comes on then when you start it it goes away unless theres a problem..
from my experience it may or could be ur fuel pump that happen to me the same thing and i took it in n they scaned it and it was the fuel pump so i had it replaced and they change the filter too. hopefully it is not that for u cuz it was 900 n something to haveit replace with parts and labor warranty covered 400 i paid the rest.
A similar thing happened to me.
I was juts merging onto the interstate and I had just put it into 5th gear. About 10 seconds later my rpms dropped to 0 and so did my speedometer.
Everything just shut off, and the engine would not start when I tried it so I needed a jump to get me going.
My check engine light came on. I realized later that I had hit the key with my knee and it hit it a little out of position. [8D]
Not sure maybe you did the same thing, i dont know. Good Luck though.
I dont want to jinx myself but it seems to be running smoother now. It has never had a problem accelerating or while in gear. I had my car in nuetral with my foot off the clutch that it supposidly when the IAC takes over. If this doesnt solve it I am gonna try the fuel filter then the fuel pump. Hopefully this fixed it. Wish me luck!
ORIGINAL: NORTON98
Can you get a IAC at a autozone or napa auto parts or do you have to go to a ford dealership?
Mike
Mike
