fog lights
fog lights
i've been having a problem with moisture in my foglights and it's killing my bulbs pretty quick. i think this is a pretty common problem, but i need something to fix it. i'm thinking about using something along the lines of transparent bathtub caulk to seal up the parting line, but has anyone done anything else that has worked to make a moisture tight seal, or do you think this will work?
RE: fog lights
dont know about the fogs, but my headlight used ot fog up with moisture and some good quality, outdoor silicone did the trick, if u do use silicone, make sure to mask everything off cause when u get silicone on something u have very little time to get it off with rubbing alchohol after that its there for life.
jwog666
12-27-2021 08:09 PM
lincolnshibuya
12-08-2015 04:37 PM
