wanna fix my foglights? please help
for some reason my right side fog light keeps going out. it will last about a few weeks and then all the sudden its out again. now correct me if i am wrong but if it was the ground wouldnt it burn out right away. and another thing that i think might be the cause of it, both of my fogs have very small holes drilled in the bottom corner, now is this to allow for air flow so that water cant get trapped in the there or is this a possible place where t water is getting and shorting it?
RE: wanna fix my foglights? please help
Does it rain a lot where you live? I had a similar problem happening on my Pontiac awhile ago and it turned out water was getting inside the tail light housing and as soon as it touched the bulb, it would blow it out. Maybe you're getting water in there somehow and it's killing the bulb. Does it happen on a regular basis?
I never noticed the holes you are talking about on my car and it's in the body shop now so I can't go out and look for you.
bradleyb
11-27-2015 07:50 PM
09-25-2015 09:06 AM
