i know ditto about nitto
RE: i know ditto about nitto
chech the salvage yard and/or ebay to get a spare set of rear wheels. then buy Goodrich D/R's and then only put those wheels on before you go to the track/or to race. i would pay for this by buying Khumo's on all four corners for street use. these can be had at tirerack.com for less than $100 apiece. i'm too lazy to do the math, so you may be out of more money up front, but you would save in the long run.
MD, i have a friend that has the same exact problem you do(runs out of gear) and he has a set of D/R's mounted on a spare set of rear wheels. the D/R's he has have a VERY tall sidewall to add some gearing. he's not running as fast as you are, but in Texas he's running a 'non-adjusted to sea-level' 12.6 e.t. anyways, i'm sure you already thought of doing this, but if not, it could be a cheap way to put 'just enough' gear back into it.
randy
96' LT1 Corvette
randy
96' LT1 Corvette
Get BFG's and you will be getting new ones in 10,000 miles.
Nick
