LOL another Grille delete question
Ok i was reading the instructions for the kit and it says something about painting and such? I got it from americanmuscle.com and its all black like i assumed it should be? You dont have to paint it do u? And what exactly do u have to do for install? I hear some say u have to remove the headlights and some say its just like 3 bolts. Which is it? And my chin spoiler wont unbend.....
RE: LOL another Grille delete question
i didnt paint mine, i got the 3pc from blueoval. i did NOT remove my headlights and it took about 15min to instal.
i followed this how to
http://members.***.net/red9r/Install...01%20Grill.htm
the hardest part is pulling the bumper back and getting to those screws under the bumper [:@]
ok... well I just installed both the delete and the chin... you DON'T paint em... leave them flat black...
for the delete, first take off the 4 screw/rivet things on the top to remove the shroud and loosen the top of the grill... now that you can pull the grille forward (not too much, it's attached to the bumper by 4 more screws) there's 4 screws you need to loosen... mine were 7mm bolts that were 'clipped' in... idk if it's different on ohter stangs... but I'm pretty sure they're all the same.... but what you want to do is pull it foward, and with the wrench remove each bolt... start on one side and work down the line, it'll get easier... after those four the grille should come right out... then it should be self explanitary from there.
for the chin spoiler, let it unfold, help it out a lil by proping it the way it should look in the warm... then when you're ready to put it on, take it outside and let it adjust to the temp of where you're installing it... after an hour or so, tape it up onto the car (it's a pain, but you gotta drill holes) after that drill out the holes 1/4 inch size WITH the spoiler in place and work from the wheel wells in... it should be a lil bit recessed behind the lip of the bumper... don't do what I did and try to mount it flush all the way around... it came out well... not normal... it looks fine, but it's supposed to be a lil bit behind the lip.
u dont have to remvoe the headlights, but it makes it a lil easier to pull the bumper up to get to the screws IMo, and their very simpel to take out, theres only 2 clips, and unscrewing the bulbs, good luck
ORIGINAL: Adam03GT
what do you mean pull the bumper down? Just put pressure on it to hold it down? I get paranoid bout hurtin my baby
or you can take the bumper off entirely... whichever ones easier for you
ORIGINAL: Adam03GT
