iac location
12-27-2006, 09:23 PM
iac location
Where is the iac located and how do i clean it, sorry if dumb question but i have no clue where it is. Thanks
12-27-2006, 09:27 PM
RE: iac location
clean it with carb cleaner
[IMG]local://upfiles/15840/71C7AF9556B74C25A93088401D0091A9.jpg[/IMG]
[IMG]local://upfiles/15840/E5A84ED8067C4AB9A05EC23D12304C1B.jpg[/IMG]
12-27-2006, 09:28 PM
I ♥ Acer
RE: iac location
Here. Remove the 2 screws and use carb cleaner to clean it up.
[img]
12-27-2006, 09:33 PM
RE: iac location
Is it ok if the carb cleaner goes in the rubber hose, do i need to dry it and stuff after or can i just screw it back in. Thanks
12-27-2006, 09:36 PM
RE: iac location
It might be a good idea to remove the rubber hose before you spray it.
12-27-2006, 09:41 PM
I ♥ Acer
RE: iac location
Quote:
ORIGINAL: Gumby
Remove the IAC completely from the car. Take the plug off, remove hoses. Then remove the IAC. Then clean it, let it dry, then reinstall it.
12-28-2006, 02:04 AM
RE: iac location
Isnt that also where you put seafoam (when using it), and what does cleaning it do???
12-28-2006, 02:08 AM
RE: iac location
nooooo, people put seafoam in the PVC valve hose. not the IAC.
12-28-2006, 02:17 AM
RE: iac location
O, ok, I had heard it was in somethin with a C valve just wasent sure which one.
12-28-2006, 02:19 AM
RE: iac location
what does cleaning this actually do and how often should u clean it
