How Can You Tell if a COP is BAD?
RE: How Can You Tell if a COP is BAD?
[quote]ORIGINAL: aode06
NO YOU WILL NOT GET A CODE 70% of the time till the car does not want to run
Have it put on Oasis at Ford, you may have several issues, . Had a 4.6 with 4 bad Cops and it idled wierd and miss every now and then.
No codes, Oasis will test each one and monitor the system, way better than the ECM can do its own self[:-]
if you have a bad cop, I have 8 Excellent ones from Ford. What we do is repalce all eight under warranty and keep the good ones to ourselves, in this guy case, his misfire were the garbage platinums in the motor and not the COP'S, so I have 8 of em with 10k on them, still smells brand new from an 2002 4.6
Oasis?! Thanks. Usually don't think of Ford when I'm working on my Ford. You're right...usually no codes on a lame COP.
i think i have a few bad ones myself, a guyfrom another forum had three bad coils so the one-coil-swap thing didn't work for him either and all the coils passed the resistance test and itnever threw a code, so the possibility of multiple bad coils is very likey.
from my experiences, bad COPs tend to be more apparent at lower rpms ( under 2K) so i think i'm gonna be a test mule for these link
ORIGINAL: 4.6LPoppy
[sm=helpout.gif] How can you tell if you have a bad coil on plug? In the past I have stuck a new one in the holes until I found where it smoothed things out. What happens if you have 2 bad? This method won't cut it. Is there a tester?
2 of mine went bad once the CEL came on the other didn't I check the OHMS and the one that ended up being bad i was getting the correct readings i finally took it to a shop
my bad COPfelt like it spittin and sputtering thats how both of mine felt almost as it was skipping...
KingRando
10-02-2015 08:06 AM
GT350 S550 Tech
09-29-2015 03:29 PM
