rear wheel bearing
RE: rear wheel bearing
You're thinking of the front sealed bearing/hub assy.. A rear outerAXLE bearing is usually like $15 per side, plus another $5 for the axle seal... Are you absolutely sure it's the outer bearings and not the rear diff going??
Doing rear bearings aren't hard, just time consuming.. You must pull the rear axles from the axle tubes, and such.. I believe there's a "How To," somewhere in the Stickies...
JT
JT
Luke9222
10-22-2015 11:55 PM
Dragonus18
09-09-2015 01:21 AM
M3hunter
09-05-2015 03:42 PM
09-01-2015 08:16 PM
