gears - not a normal post
Before I get flamed, I am not going to ask "what gears balh blah blah" I KNOW I want 4.10s (ftw!) But I used to be able to find the entire install kits with gear oil and all the crap for like $199... now I cant find them anywhere - Can anyone help me with this? thanks
(figured might as well since i have to take it all apart to do the pinion seal anyway....)
RE: gears - not a normal post
OK, so since i have a pinion seal leak, which COULD be bad bearings, should I spring for the master bearing kit - also, do we have a discount code for brenspeed ?
I don't know of a discount code for Brenspeed. Even if there isn't one, be comforted to know Brent will take good care of you if something ridiculous were to happen with your order.
The bad seal could be nothing more than a bad seal, every Ford I've owned the diff. leaked and I had to replace the seal. Either way, it's a good idea to do the bearings while you're in there for the gears.
last question, stage3motorsports offers two different 4.10s from motive - the normal one $129.99 and the "performance plus" $159.99
Is there really that much difference for the occaisonal strip driver?
Contact, brent@brenspeed.com, tell him that you're a mustangforums member and what you want and he'll give you a good discount.
musnicki
09-23-2015 07:11 AM
