PI swap performance changes
I was thinking of doing the PI swap but figured I'd save the money to go DOHC, but I'm just curious, what was the major change with the PI swap, by this I mean could you feel the power right when you pushed on the pedal, or was it mainly just in the 4k RPM range and up it's felt?
RE: PI swap performance changes
you can really feel it. before when you floored it, would pull at low end ,and it would run out of power at about 4k . with the swap it pulls hard the whole rpm range. it also helps to have gears.
ORIGINAL: silverstang1996
But, it you saved and went to 4v, it would be alot more.
jaiidutch
09-14-2015 10:29 AM
09-08-2015 11:50 AM
