I am really intrested in them, but alot of people say they cause some kind of idle problem, and i also heard they make ur a/c weaker? anyone with experince with them?
No, it wont make anything weaker. My a/c was fine in my 2v and my voltage was fine... it's all a bunch of myths.. the only way the voltage would be affected was if you have a ton of things running.
Don't use A/C pulley, most of the power is from the crank anyway. I installed mine BBK with A/C and it does reduce power, I kept stock pulley for alternator you won't have a problem.
A/C pulley???? There are only pulleys for the crank, alternator and water pump.
