Gauges Max Out at Start
Lately ever since I the problem with car car started which I think is the alternator, Every time I start my car the gauges max out like I reset the computer.
What could be causing this? Is is because my alternator is bad and the computer is resetting?
RE: Gauges Max Out at Start
It doesn't sound like the alternator. If it was, the battery would be dead and it would not stay running after a jump.
Sounds like somehow you are loosing the constant power supply to the computer. Are the preset radiobutton reseting?
My battery did die. That is the thing. I have run it about 5 times in the last 3 weeks since its been off the road. The battery died now. I am guessing this is the alternator.
you replace the battery? or just charge it? I would guess battery. When this happened to me, I had the battery tested, it failed, I replaced it, problem solved. G/L
If you can, get the battery tested, if its good, then I'd go to the alternator.
