Would a set of muffs be just as good as a catback?
RE: Would a set of muffs be just as good as a catback?
ORIGINAL: Hound11
Thats interesting, bc I sure do be seeing people ridin with some fat *** pipes, I be like damn!
f no
2.5 is the optimal size toexhuast ratio for our vehicles since they are not f/i. smaller exhuast diameters show less horse/torqueon a dyno meter than a 2.50 now on my audi i run 3 in turbo back exhuast because it let's the exhuast exit faster than a smaller diameter pipe and in turn makes my turbo spool up faster. If i didn't do this i could get turbo stall. which suchs. So if 2.25 was fine everyone would just say do it but it is not. if you just want a loud mustang than change the muffler with a piece of straight pipe but you looking for performance and plan on doing stuff down the road the get the 2.50 diameter. if you don't believe. then do a search on google for this.
im willing to bet that if you took a stock stang and just welded in some flowmasters then threw it on the dyno.....write down the numbers/results....then go and change JUST/ONLY the cat back piping leaving/still using the flowmasters....put it back on the dyno....i bet you dont see any difference in numbers...if you do....it would only be like 1 maybe 2 hp(wich isnt noticalbe)...in other words....yes a set of muffs would be just about as good as a whole cat back.
ORIGINAL: MoKo_04GT
ORIGINAL: MoKo_04GT
well noob sounds like you should go and do this.but i bet you, you will be sorry.
ORIGINAL: mustang_pa
ORIGINAL: MoKo_04GT
good thing about cat backs, there usally come with some good lookin tips. Take Slp's cat backs, Those double rolled tips are sex. But if you bought them seperatly, and then the mufflers and had a shop weld all that it, youve pretty much paid for a cat back. Might as well just order it with the new mandel bent piping and be done with it. I personally only have weld ins. Im going to do a cta back but didnt have the money, so i just had some welded in for a lil change in exhaust tone.
there is a very MINIMAL difference between the cat-back and weld in mufflers. spend the extra money and get the catback for almost no results....the only difference may be sound...just my .02
