Nitrous?
RE: Nitrous?
ORIGINAL: StockD15b
if ur wanting good times, check this out. https://mustangforums.com/m_2459394/tm.htm
for optimal saftey. Fuel pressure safty switch,wot switch, an arming switch is always good. And you could go with a window switch as well.
FPSS-will cut the spray if fuel press. starts to lean.
WOT-only activates at wide open throttle.
Arming-turns all the others on.
Window-will activate at a set rpm range. Say 3k-5k.
I personally only use a arming and wide open.
Just incase you are wondering,
WOT+ARMING comes with NX kit.
NX FPSS
ZEX self contained windowswitch(with traction control)
Any bottle heater will work, the choice is if youprefer a thermostat ornot.
