Please Help! URGENT OBD Code
RE: Please Help! URGENT OBD Code
ORIGINAL: Car_Ramrod
bump...educate farva lol.
P.S. I got my car tuned w/o the use of ANY oxygen sensors. You dont even need the ****'s Get a tuner and cut them off, then get it tuned using the MAF.
ok...so i called my tuner today...and he said he wants to get it on the dyno to check it out. the problem is how far away he is. but here is the problem as i understand it...
P1132 Lack of SWT Rich H02S1 seems to mean my oxygen sensor is bad or not reading properly. HOWEVER...my tuner said that this problem should not effect driveability at all. while i have not driven my car since it happened...my tuner said the car should not have leaned out the way it did. when the CEL light went on the wideband went lean and the rpms started dropping slightly. he said that the 02 sensor should not effect this at all. anybody have any ideas since i cant get to him right now? my only thoughts are 02 sensors or maybe a problem with the MAF since its pegged at 5200...but why would this effect the idle?
any help is very much appreciated. thanks guys.
lincolnshibuya
12-08-2015 04:37 PM
