i need help
i need help
ok i dont have a pic but the 4.6 guys will no. ok so i was cleaning out my engine today and i movedthis twist thing that is on the fuel rail its on the front passenger side. ever since i moved that i havent dared to turn the car on or run it what is that twist thing. i thought it was like a fuel thing, and it probably is, any help would be good. on the pic, where the fuel injector is at the top thing
RE: i need help
I beleive you are refering to the schrader valve. This is used to check fuel press and stuff like that. If you take it off it will look like a valve on a tire. Just make sure its tight.
RE: i need help
yeah just tighten it like you would the cap on a valve stem. Its no big deal you can take it off and look at it, the only way fuel will come out is if you push in the valve, just like the air in a tire,exact same thing.Bottom left of pic above fuel injector correct?
