COOL Pedal Mod.. and cheap!
Things required:
[ul][*]10Min[*]Skate board Grip tape[*]Razor blade[/ul]
Step 1. Remove the rubber on the clutch and brake. and clean
Step 2. Cut out two squares bigger about 1/2 inch bigger than each pedal remove the the backing and place on the pedals.
Step 3. Fold execess down just a little bit and take like a nickel and trace out the edges of the pedal it should leave a chalk like line around the pedal.
Step 4. take the Razor blade and cut around the pedal using the chalk line as a guid.
This works great and is really cheap!!!! the only problem is it doesnt last for more than like 6 months. but it only takes like 10 min to do..
Try it you wont be disapointed And it Feels Great!!
RE: COOL Pedal Mod.. and cheap!
would it not be ruined the first time your feet were wet. but in the dry your feet would deff not slip
Once it starts to where down they will start to slip. I have had one sheet of grip tape for 3 years though!
ccdguy
09-19-2015 05:20 PM
