Cams for 98 2v
RE: Cams for 98 2v
Well how about a little more info. Are you running them on stock heads? PI heads? Aftermarket heads?
If you're running them in stock non-PI heads, I'd suggest grabbing PI heads off ebay for next to nothing.
RE: Cams for 98 2v
I just suggest the PI heads because they are dirt cheap, and if I wanted to go more aggressive on cam I'd want PI heads as well, then you have more freedom on more aggressive cams. I figure that if you haven't upgraded the heads yet, then you probably dont want to spend a ton on cams alone. I just don't see spending too much on cams to be cost worthy unless you're going all the way. Swapping in a PI intake and PI cams however will give you quite a nice gain. Almost as much as a full PI swap.
Edit after reading your latest reply: If you don't know what you're doing yet, then I'd definitely just do PI cams for now. You can get them for $100 or less lightly used so you wont waste anything if you want to go more aggressive in new heads later. At least this is what I think I'm planning to do. A PI intake and cams and a decent tune should get you a good 50 HP give or take some depending on the tune.
RE: Cams for 98 2v
ORIGINAL: droptoppony
you could also just swap in some PI cams and gain a solid 15rwhp...
i have a set in my garage if you are interested [8D]
RE: Cams for 98 2v
ORIGINAL: AJ97GT
I'll let him have a first chance at it since you offered them to him here, but if he doesn't want them then let me know how much you're looking for. I might be interested in gathering a few parts together.
first $100 takes em, i might even have an extra set of cam bolts to throw in..maybe
