Bought a can of Sea Foam...Best way to apply?
Old 01-02-2007, 09:56 PM
CobraStangGT16
CobraStangGT16's Avatar
Default Bought a can of Sea Foam...Best way to apply?
As posted, I just snagged some seafoam, because I heard from other guys here that it does wonders for their engines. It was like 7 bucks at pep boys so I grabbed it. It's a 16 FL OZ bottle.
My question is, I don't really see any directions for use, and I'm sure there are different procedures for each application, right? Can somebody give me the low-down on how to use this stuff to work best for my car? A detailed procedure would be greatly appreciated. My car has 98,000 miles on it, and is a 5-speed manual. Would it be best to add it to fuel, oil. injectors? I need help!
Thanks guys!
CobraStangGT16 is offline
Old 01-02-2007, 09:58 PM
mikev08826
I ♥ Acer
mikev08826's Avatar
Default RE: Bought a can of Sea Foam...Best way to apply?
Why would you put seafoam in your engine?
mikev08826 is offline
Old 01-02-2007, 10:06 PM
CobraStangGT16
Why not?[&:]
Old 01-02-2007, 10:33 PM
BlackMustang02GT
BlackMustang02GT's Avatar
put1/3 in your brake booster line (vac) put 1/3 in your feul, 1/3 in your oil and your good
BlackMustang02GT is offline
Old 01-02-2007, 10:42 PM
mikev08826
I ♥ Acer
mikev08826's Avatar
ORIGINAL: CobraStangGT16
Why not?[&:]
I just don't get why people put the stuff in their engine. If it's not oil or fuel,why??? I understand tons of people use itand it's been around forever, just seems like a gimic to me...
Old 01-02-2007, 10:45 PM
CobraStangGT16
Whats wrong with a 7 dollar gimmick that makes your engine run like new?
Thanks blackmustang, I've heard that combo used by other guys too. But I kinda meant like, how long to wait, how long to drive around, etc. Some guys say wait 5 min, some say 15, thats why I ask.
Also, do I need to change my oil before/after I use it? I'm due for an oil change, and this seems like a good time to do it.
Old 01-02-2007, 11:44 PM
01blkonblkGT
01blkonblkGT's Avatar
i dont like adding anything to my oil. but i did remove the pcv line from the upper plenum and poured about 1/2 a can thru there while the engine was running. i poured it slowly then quicker until the engine about stalled. left it in there for about 15 minutes. its supposed to loosen all the gunk off of your valves.
i started it up and let it run. it smoked like hell for a while, but after a day or 2 it stopped.
i wouldnt run it hard until it completely stops smoking.
i am getting ready to do it again soon. only this time i'll leave it overnight
01blkonblkGT is offline
Old 01-03-2007, 12:23 AM
CobraStangGT16
So did you pour it until it stalled, then left it? Or did you go back and shut it off before it stalled?
And I'm still not sure exactly where to pour it into the pcv line, like which hose or opening? Can somebody give me a picture?
Thanks.
Old 01-03-2007, 12:27 AM
kcp1989
kcp1989's Avatar
half through a vacume line thats leads to crank case and rest in gas tank.
It breaks up carbon build up and cleans about everything it contacts. injecters, everything. make sure you get your oil changed within 500 miles to get rid of all that gunk losened up.
I put some in my friends acura tl with 110k miles and its like a whole new care. gained 3 miles to the gallon on average and pulls much harder
kcp1989 is offline
baddog671
07-26-2016 01:20 PM
Dathan
10-05-2015 05:52 AM
BeatnikFink
10-01-2015 08:00 PM
ThatJuanStang
09-25-2015 08:01 AM
lmurf60
09-24-2015 10:07 PM
Quick Reply: Bought a can of Sea Foam...Best way to apply?
