Do you think synthetic oils really increase power?
#21
RE: Do you think synthetic oils really increase power?
I voted YES because I know it does. We have tested it more than once on the Dyno and it averaged out between 4-7 HP, one was 9 HP but it may have been a fluke. Its not something you'll feel by SOTP but when your looking for every bit you can get out of it then its worth it, good luck.
#23
Wrongo, buddy. Synthetic does not come from the ground, which is why it's called synthetic.
Synthetic oil is manufactured to have molecules of the same size which increases in lubricating abilities while resisting boil-off and gelling.
All oils have additive packages, and some dino oils even have additive packs similar to the synthetics. The difference is the oil itself.
And, yes, synthetic oil will gain some power. As stated previously, however, the amount of power is low, but will vary from engine to engine based on clearances and the number of bearings/bushings in the engine.
From personal experience, a '91 Explorer 2wd/5-spd gained 2mpg (16 to 18) with just a switch to synthetic at 130k miles. No leaks, no problems.
ORIGINAL: trance565
wait, im confused, how is this a question? all synthetic has that is different from regular oil, is the additives last longer, they have nothing that can increase power, dunno how you, or anybody got that idea.
edit: less friction = more power ... i suppose, but if you cant measure it, then technically it doesn't exist from a realistic standpoint.
#24
ORIGINAL: CoolAid
Yes. All stories about synthetic blowing through old seals and all the other "too many miles stuff" is all myth.
ORIGINAL: jagrave
my mustang has 97000 miles on it. is it safe to use synthetic oils in it, especially sense they have never been used in it?
TfcCDR
09-14-2015 12:08 PM
09-08-2015 11:50 AM
