Fan only works on high! help
Okay, so my fan only works on the high speed. I've looked over the wireing diagrams and it looks to be a problem with the blower motor resistor. Any ideas where I can find this resistor? I havn't had a look up under the dash but when I took the climate controle face out of the dash the wires seem to run deep down into the beast so I dont know where to find them! Anyone been down this road befor?
-Mark
-Mark
RE: Fan only works on high! help
If you look under the heat duct where the blower motor is you will see it right above the motor. There is some wires with a plug attached to it. It's very small about an inch by half inch.
The same thing happened to my car and it was the Heater Motor Resister. It was like $16.00 at the Ford dealer.
HIS S-197
08-10-2015 05:47 PM
