MGW?????
MGW?????
Ok i just got my MGW shifter, i did every step on the book that they gave me.. For some reason it doesn't shift right.. first - second perfect when i shift to third and reverse it feels like it's in neutral and it feels like the ball is coming out of the trans cup... please help!!!!!!
RE: MGW?????
you dont set the shift stops if its a tremec 3650... did you put the plastic black cup on the bottom of this shifter? I did that at first too.. but check your stock shifter if you see that black plastic ball get it on there right away.. the guys at MGW told me that, you not having it will be REALLY bad..
RE: MGW?????
ORIGINAL: rickydawg
It seems like the shifter is not long enough on the bottom to stay in the shifter cup it come out in third gear.. I dont set the shift stops if its a tremec 3650??????
RE: MGW?????
ORIGINAL: rickydawg
I will try that first thing in the morning thanx.. Also i was told that i have tremec 3650 transin my car it's a 2002 gt hope fully i was given the right info...
RE: MGW?????
Ricky, when you take your shifter out 2morrow look at the bottom of it - Make sure that black plastic cup is on the bottom of the shifter - that sounds like what your problem is... I had the same thing with mine when I first installed it
ORIGINAL: rickydawg
