Trans %^&* up
RE: Trans %^&* up
Thats the truth, just hide any sign of Nitrous and you should be fine. You can change a lot of things on a car without voiding the warranty. If its a Ford ESP warranty the only thing that will void it is the addition of "A supercharger or Turbocharger", it states this in the "whats not covered" section. The Moss- Magneson act gives the consumer a lot of help. The dealer must Prove that your different XYZ part caused this to happen, good luck.
RE: Trans %^&* up
As long as Ford can't say your aftermarket part caused the failure, you are good, unless you have Nitrous or a SC/Turbo. Warranty Tranny work always depends on the dealer. By law you are supposed to be protected, but that doesn't seem to be worth a damn to Ford or the dealers.
Matt's 95 Stang
10-05-2015 07:16 AM
