Street Suspension List
Hey guys, I've been doing some research for a while about suspension. My car will be pretty much 100% street driven, DD, and rarely, if ever, visiting the drag strip. There is a pretty good chance that by mid summer I will be adding a Vortech, and I plan not to run more than 8 psi. I dont plan to build the engine, so this is primarily a reliable DD that wont see over 400 rwhp. I put together a list of suspension components that I'm looking to purchase within the next few weeks, and wanted to see if I was missing something important for my application:
Tokico non-adjustable Shocks/Struts
FRPPC springs/ H&R Sport Springs
Maximum Motorsports Full Length Subframe Connectors
GMS Upper/Lower CA's
Thanks.
EDIT: If anyone has experience with these products, good or bad, please chime in.
Thanks.
RE: Street Suspension List
running with those shocks/struts i can say it def. feels alot nicer then my friends GT, im adding MM sc in 2 weeks ill let you know how those + shocks feel...as is cornering and turning i have an advantage over friends but since he has gears and sub frames he beats me at straight line speed =/
ORIGINAL: dsg04gt
Anyone?
Anyone?
https://mustangforums.com/m_2503150/...tm.htm#2512418
Prodigy: Thanks, I was looking for user opinions.
Jackrocket: I saw your posts in that thread earlier, and actually based some final decisions off of that. You give good info, and your suspension setup is heavenly lol.. Thanks
If anybody else that has first hand experience with FRPP C Springs or H&R Sports can chime in, that'd be great.I want a firmer ridewith a slightly lower stance,but not so much that straight line accel. is compromised.
ORIGINAL: dsg04gt
i have ford springs.... .75 back 1.12 up front i had to take the rubber isolators off the springs in the rear to get it level...
The Ford Racing "C" springs are very comparable to the stock springs that are on the GT Bullitt. I am currently running Bullitt springs/struts/shocks on my car. Not a huge difference in stance vs the stock springs. Maybe 3/4" drop if that. At the same time I put on Granatelli upper/lower CA's.This combination makes for a very streetable car with significant gains in off-line traction, cornering ability and over-all ride. The ride is a bit firmer than the OEM stuff, but I like it. The onlycomplaintthat I have isthe springs do not lower the car far enough for me. I will be replacing my springs with Eibachs to get a lower stance.
mungodrums
09-28-2015 10:54 PM
mungodrums
Suspension
09-24-2015 10:12 PM
