car died for 1st time
RE: car died for 1st time
Same thing happened wit me once...but hasnt happened since...weird ****...maybe its my fuel pump? sometimes its hard to start up...it just doesnt crank up till the last second or if i have to turn the key on again itll start up right away...is this covered under warranty?
ORIGINAL: sandcracker21
UPDATE:
today on the way to work my "check fuel cap light" went on.
after i checked that the cap was tight, which it was, the light was still on
it was on after work, then after 15 min of drivin it goes off
i have also noticed that the replacement bulb for the one that was shattered is
definatly duller and not as bright then the other fog light bulb
car has yet to die a second time
UPDATE:
Well... I can guarantee it has nothing to do with your shock/strut and fog light replacements.... you hit a bump so hard it shattered your fog light?? Thats no good! If the car is still running normally with no bad noises I have good news... the motor is not blown! lol.... since you replaced the fuel filter recently I rule that out... how bout air filter?? Really though... with the fuel cap light (i didnt know they had one) I would say mabey a sensor of some sort went out when you hit the bump... and if you have a warranty I see no reason why this would not be covered... full warranty you should have no problem.
well after i ran into a curve and mest my front end up and raditor my car would start and cruise for a lil then die but always started back up. my friend says it maight be cuz my car was overheating and it didnt want to run he says its nothin to worry about u guys agree?
ORIGINAL: GT STANG
I see you have a Steeda CAI- when you installed that, did you remove your MAF screen? If so it is either that, or your IAC. My old mach 1 would die every once in a great while, and it was due to the CAI that I had on it, and I had removed the MAF screen. My GT also dies every once in a great while, but that is due to my IAC. If you removed the screen, put it back in and you shouldnt have the problem again.
MEISTERSNFB
03-31-2020 07:50 AM
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
