gear install
RE: gear install
I am in the middle of doing mine right now. I got f'ed by the master rebuild company. They assured me my parts would be here sat. and they didnt show, so now i dont have a car today. Anyway, you need to prolly get at least new pinion shaft bearings and races and a seal, plus the oil like you mentioned and some rtv. If you need any help, I just went through learing all this this weekend, so its still fresh in my mind.
RE: gear install
Get a bearing kit they come with all the bearings and shims needed to do the swap. Dial indicator to set the backlash. IMO its a good time to change the wheel bearings and seals but not necessary.
RE: gear install
ORIGINAL: BraMas
RE: gear install
I wanted an ebay complete kit,,but opted got the jegs kit instaed,,comes with everything except axle bearing and axle seals,,which I found locally....comes with the limited slip additive and redline synthetic gear lube....and it has the richmond install kit,,,,good bearing and races not koyo china bearings..also comfirmed this morning,,,,the gears ARE motive white box....same as on ebay...
http://www.jegs.com/webapp/wcs/store...55861_-1_10167
555-60027k ,,installed saturday and still giggling.....
RE: gear install
Where can I get a bearing kit? I already have the gears and will use Royal Purple oil which I've heard does not need aditives. Does the bearing kit need to be for the specific 3.73 gears or does it work for all? CanI get the bearing kit at an auto parts store or is it only available on-line? I apologize for beeing such a noob, thanks for the feedback.
RE: gear install
You can get the bearing kit online pretty easily. You could also call a local parts store to see if they carry it, but they will likely have to order one anyway and it may be more expensive through them. Can't hurt to call and find out though. Here's a link for one online: http://www.americanmuscle.com/rearendrebuild.html
RE: gear install
ORIGINAL: SINISTER
