My final cam degreeing results!!!
RE: My final cam degreeing results!!!
ORIGINAL: phalcrow
I heard that knocking sound when I put on my 270's.... except it was my valves doing some machine work on the pistons.
yep I tonight I am grinding the key ways off and retarting the passenger side 5 degrees and the driver side 3 to get my center line of 109. and she will be running by the end of the week.
Good News!!!!
Well I got the passenger side done I retarted it 5 degrees it know reads 144 degrees ATDC and 74 BTDC which is 109 degrees where my cam car is supposed to be. so I am happy now I need to finish up the driver side and retard that on 3 degrees
no I rebuilt my motor about 4,000 miles ago with the cams in. but developed a valve tap and decided I should degree my cams. but I installed the cams with the motor out of the car!!
Have you noticed any power gains from degreeing the cams? I'm thinking about doing it but only for the extra HP. I already have the PTV clearance becuase I got my new pistons fly cut.
nmra1965
Other Professional Racing
09-26-2015 10:46 AM
