Heads and Cams!!!
RE: Heads and Cams!!!
New injectors = new calibrated MAF. Click here
New heads require new bolts/studs, too. Ford loves those damned one-time-use torque-to-yield bolts. ARP studs should be in your shopping list.
So i need new studs/bolts and new gaskets. . . anything else? Also how hard is it to install the new cams? Is it as easy as poping in the new cams on the new heads or is there some issues i need to know about. Ive done head cam jobs before but that was on my old 95 pushrod chevy 350[:'(]
These folks can help you with that far better than I can.
https://mustangforums.com/m_2518516/tm.htm
Best heads in my opinion would be MPH 2.5's and a set of custom grind MPH cams.
MPH = www.modularpowerhouse.com
My ARP's are torque to yield one time use bolts, too.
ORIGINAL: 04BlueGT
