saleen on nonpi heads
#21
RE: saleen on nonpi heads
not sure on the specifics as far as your question, but i do know that series 4 wont work with your return fuel system setup. i wanted to use a series 2 on mine but didnt for the same reason. youll have to look into a way to doit, as your fuel rail wont fit due to the blower, maybe a custome line setup would clear it.
#23
its because the 99+ uses a returnless system and has less plumbing up front, so the blower itself fits no problem. i havent heard of anyone trying to convert to returnless as it is usually the other way around, but i guess that could be an option. other than that, a custom fuel rail setup will be needed. this is why i went centrifugal, no issues whatsoever, and its a much better setup.
#28
no one i know has done this, and i couldnt find any info other than converting your return system to returnless. i dont know if someone else mentioned it, but doesnt kenne bell make a unit that fits the 96-98 fuel rail?
#30
i wouldn;t change to a returnless setup, i would just use aftermarket fuel rails
http://modularpowerhouse.com/product...0da53b9f53b642
