Substance Under Oil Cap
i changed my oil and oil filter. when i was putting new oil in I noticed a yellow substance with the consistency of margarine accumulated on the inside of the oil cap.
what is that from?
2002 Mustang GT 23,600 mi.
what is that from?
RE: Substance Under Oil Cap
Sounds like you might be getting water in your oil. Head gasket, intake manifold etc. Check coolant levels, if all is good, give a good cleaning along with an oil change and keep your eye on the cap.
Normal operating temp is just the coolant, not the engine itself. It depends on the type of trip, but 15 miles will generally get the engine hot enough. Five is likely short. When I actually lived close to work (<1 mile), I'd drive a 20 mile loop every other day on the way home.
