Gauge Install Help
RE: Gauge Install Help
i just installed my guages last week, fuel pressure was the easiest one.
i take it your car is an 04. so your going to need a fuel rail adapter first, i got an nx unit from summit. this is where your sender is going to hook up to, mine fit perfectly, just make sure to use some thread locker. for the ground i just used a bolt by the fuse box.
your going to want to go down to the autozone and get some mini add-a-circuits. connect the red wires to one and the white wires to another one.stick the red wired one into fuse block 20 and the white ones into fuse block 37 i belive(right numbers but may be white-20 and red-37). they will dim with your other interior lights.
ORIGINAL: MustangChris04
$49.28 FOR THE ADAPTER? are u kidding me? Is there another way to hook it up?
Im also going to be installing a wet kit of nitrous which will also need a fuel source.
Galactic
04-29-2019 02:56 PM
