At 300 RWHP N/A: Go to 24 lbs injectors?
Old 01-11-2007, 11:47 AM
01BlueCobraVert
01BlueCobraVert's Avatar
Default RE: At 300 RWHP N/A: Go to 24 lbs injectors?
I put them in my car. I have 282 RWHP W/O a tune, so with one I should be close. Sean Hyland recommends you change them and he knows what he is talking about. You can get a cobra MAF and save money. I got a pro-m through ebay for like 50 bucks used.
01BlueCobraVert is offline
Old 01-11-2007, 03:39 PM
droptoppony
droptoppony's Avatar
your stock inj and MAF are more then up to the task of a 300rwhp N/A setup...no need to change them. FI is different at 330 or so you will need atleast 30lb inj's but the stock MAF is still good. To recalibrate your injectors on a 96+ it is done in the tune.
droptoppony is offline
Old 01-11-2007, 03:59 PM
ZW99GT
ZW99GT's Avatar
ORIGINAL: droptoppony
I guess N/A is different. My tuner said my GMS MAF was maxed out (when hes was checking maf counts), but mu injectors were fine. 24lbs.
Just upgrade and go. 320rwhp here
ZW99GT is offline
Old 01-11-2007, 05:10 PM
Armydad
Armydad's Avatar
Right now I am in the process of gathering the parts. But basically with stg 2 ported PI heads and good cams, then all other boltons, you should be at 300 or a little more. On stock or even mildly ported heads the bolt ons don't do much, but it seems with a PI swap, using stg2 type porting and properly matched cams, the motor wakes up and bolt ons start producing better results. I read Seans book and he has a 350HP n/a motor build that he lays out step by step. If I don't supercharge then I will mostly follow his component recomendations.
ORIGINAL: BBZracing
ArmyDad,
It is my goal to get to 300 rwhp N/A. May I ask what mods you have? I am planning on getting Patriot heads and cams in addition to my other upgrades (see sig). I am hoping that will get me there.
Armydad is offline
Old 01-11-2007, 05:18 PM
amoosenamedhank
amoosenamedhank's Avatar
I wish I had the book with me but there is a table for horsepower restrictions and injectors. 350hp is the cut off for 24lbs injectors I believe. I think the 19lbs were around 300hp.
amoosenamedhank is offline
Old 01-11-2007, 09:00 PM
Armydad
Armydad's Avatar
Yes there is. He has a chart in the book showing injector size and HP range. I believe you are correct with the stated numbers as well.
ORIGINAL: amoosenamedhank
Armydad is offline
GimpyHSHS
19
12-19-2023 01:12 PM
4cylinderplus2
10-09-2020 07:45 PM
Bokeo
10-10-2015 08:28 PM
guitarman376
09-30-2015 05:54 PM
Quick Reply: At 300 RWHP N/A: Go to 24 lbs injectors?
