4.30 Gears
4.30 Gears
I was thinking of getting these instead of 4.10s but im afraid they may be too unstreetable. I am N/A do i need the most bang for my buck but 4.56 is just way too radical so idk. Who here has or ever had experience with 4.30's?
RE: 4.30 Gears
4.30s are way to much, espically if you don't run a drag radial.
Frankly, I don't see how people run a 4.10 gear without D/Rs. My car had enough traction problems with the 3.73s and the BFG's (regular radials) I had on before the nittos.
My car acutally was slower with 3.73s than the stocker 3.27s off the line before the drag radials. The car would spin thru 1st, spin a bunch in 2nd, bog down, and then finnally catch traciton.
I can't imainge how fast the 1/2 shift must be with 4.30s... I am a fan of gear, but not that much unless its a sticky tire/strip only car.
RE: 4.30 Gears
I'm going to go that route myself. I think it will be fine, it will just be a matter of learning how to drive with them. You can't launch as hard or hit second as hard I'm sure, or you will spin and go nowhere. I say do it and just take the time to learn how to drive it properly.
RE: 4.30 Gears
glad you did not sell your car ben!
when i was deciding btw 4.10's and 4.30's i figured in the elevation (i'm ~4200).i just did not want to have to shift to fifth in the quarter. i went with the 4.10's and they are PLENTY of gear. first will spin to redline in two seconds if i'm not carefull.
RE: 4.30 Gears
Well i live on a dirt road so im not going to go with drag radials for this car becuase itll chew them up in no time. I am concerned about the traction issues though and so in that case i may go for 4.10's or 3.73's but im really leaning towards 4.10's.
RE: 4.30 Gears
I'd say stick with the 4.10's... I just wouldnt go any more than that. If you wanted to run DR's and done alot of strip racing, then I'd say get the 4.30's. I think you'll be satisfied with the pull of 4.10's tho.
Side Note: 1000 posts for me... never thought I'd see it.
