somethings wrong!!!
RE: somethings wrong!!!
ORIGINAL: trance565
could need your tires balanced, did that with my integra.
if it wasthe rotors, you would likley feel it whenever you hit the brakes, at all speeds.
ORIGINAL: mylongvictor
Maybe.... But would it different because the integra is front wheel drive? Feel different I mean?
ORIGINAL: trance565
Thats true, if it is the rotors you should feel it at just about all speeds, even when going slow and coming to a stop. It could be the tie rod ends but how many miles on the car. also check everything else that has been suggested in previous posts. If you have a local guy that cuts rotors, take them to him first to see if their warped before you spend on new ones, good luck.
You may need to put new air in your tires. The old air may be stale and sluggish.
Jk. Probably rotors, and when you change your rotors you have to change the pads also. And don't forget fluid and brake kit (new pins and such)
zanemoseley
09-06-2015 12:58 PM
