Bad Performance Prob
Ever since i put on my 75mm TB/Plenum combo from BBK my car has run like crap. When u wanna get on it it bogs down like the air/gas mixture is wrong. Would a simple choke adjustment fix this problem. Also u can constantly smell gas in the car when its running. Tell me what 2 do.
RE: Bad Performance Prob
First thing I'd be checkin for is a vaccum leak,,perferbly on the or around the parts installed.......you had to transfer the tps,Iac ,,everythinggo on and fit ok.?Check engine light on yet?
Choke adjustment? If you're in the right section, you have no control without a good tuner.
Did you disconnect the computer to let it reset? Other than that, sounds like you have an install problem. Take some pics and post 'em (bigguns hosted on a place like Photobucket would be good).
09-08-2015 11:50 AM
M3hunter
09-05-2015 03:42 PM
