Installing BBK UDP, does the piggyback pulley need to be flush?
RE: Installing BBK UDP, does the piggyback pulley need to be flush?
i had the same ones, just get it as tight as you can and straight there will be a small gap maybe not a 1/4 inch but not far from it and mine also my wabbled a lil but when the motor revs any it straightens out just tighten the crank with an impact wrench and leave it and check in a couple of days but it should be fine. o and make sure you tightened those bolts(the 3) and put locktite on them. mine started to loosen suz the 3 werent tight enough. if i had to do it again i wouldnt get the piggybacks nor would i reccomend them but since u have them already dont worry about it your car will be fine if you dont think so check on it once in a while. but it should be all good.
Luke9222
10-22-2015 11:55 PM
Golfsito
10-06-2015 11:02 AM
